Hopefully this is being posted in the right section considering it pertains strictly electrical questions...
I am currently digging into a build pretty deep (truck listed in signature) and have decided that during this whole process I wanted to pay extra attention to the electrical system on the truck. For the most part, I am wanting to keep things simple, clean, and direct. Basically ANYTHING under the hood or in the cab that is not 100% necessary for a truck that will some occasional street miles and driven to an event 2-3 times a year (predominate use on the track / dyno) I want it gone. With the stuff that I have removed thus far, I have traced the wiring back to its origin, and removed the circuit entirely.
So far I have removed / relocated:
- Entire AC system (working on removing the wiring in the cab)
- Working on removing the heater
- Removed both batteries from under the hood (plan on one 1000 CCA battery mounted in the bed when finished)
- WIF sensor wiring
- Fuel heater / factory fuel filter head
- Relocated ECM / TCM to drivers side battery location
- Relocating FICM on top of the motor
- Windshield washer fluid tank and low fluid sensor
- Coolant overflow tank / Low coolant sensor (Firewall mounted PPE style coolant tank will be used)
- Intake Air heater / wiring
Here's where my questions start. I am thinking about not running glow plugs on this truck. I understand the adverse effects of doing this ie; making it somewhat a stubborn bitch to start with cooler ambient air temps are present. But I can deal with that if it means simplifying the under hood appearance. I have set the glow plug run times to 0 seconds with EFI Live and it still seems to start fine with air temps in Wyoming currently being around 30-40* in the later evening hours. Anything colder than that and it seems to get a little bit cranky when trying to start it. I would imagine that with the lower compression ratio I have chosen for the new motor would only amplify this problem. I have seen some of Ben's youtube videos of him starting his truck without glow plugs in some pretty ridiculous cold, so this makes me feel slightly better about removing them.
In the cab I plan on removing:
- Power / Heated leather seats
- Rear window heater
- Power / heated mirrors
- XM / Onstar wiring (antennas as well)
- Airbag system
- HVAC Controls
- Trailer brake controller / wiring
What else have you guys removed on your occasionally street driven race rigs? Im sure I'm missing a bunch of stuff, but more than anything I am looking for a discussion / plausible ideas to make this truck as clean and simple (yet still functional) as possible.
Edit: Forgot to mention ABS, has anyone removed the ABS system before with any amounts of success? And I DO PLAN ON KEEPING THE STEREO!
I also plan on a fuel cell in the truck as well, curious to see if I can still keep the fuel gauge somewhat functional.
- WIF sensor wiring
- Airbag system
- HVAC Controls
