My guess is he bought used parts as they were available? Otherwise, it doesn't make a lot of sense to do. Unless he blew head gaskets & ruined heads & needed some replacements anyways?
Sounds like you're gonna try your hand in the local ws classes. It's tough & you're likely on the right track to go above & beyond typical tune & trans trucks. It takes more than that around these parts in WS.
I don't know if more air flow will make much more power when you're already air-limited in WS. I'd prolly do like Jake Fryman & go LLY/LBZ charger on the LB7.
And I'd go about 60% over injectors from a reputable shop if at all possible. They're much more expensive to get balanced but better IMO.
Good luck.
