LB7: LB7 alter fire cam injector wiring
03spoolindmax
Nov 9, 2011
674
Mi
the cam is expensive I think 1400, but they are claiming no one has broke a crank with the alt firing order. unless someone on here wants to chime in on that....
Just when i think I have everything to complete my build. Im still another couple grand away :roflmao:
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
While were at it, for LBZ.
INJECTOR - PIN - WIRE COLOR - CONNECT#
2 - A4 - light green/black - C107
5 - B7 - tan/white - C107
8 - A5 - dark blue/white - C107
3 - B6 - pink/black - C107
6 - A5 - yellow/black - C108
7 - B5 - orange/black - C108
bluessmax
Tabasco Injected!
Nov 4, 2010
1,151
Lake Charles, la
I'm doing it outside efi with my hex editor like I do on the LML stuff.
I have LBZ-LMM-LML currently mapped with firing order. I added the table into efi, however, locating it was in a editor.
DPC
323
Adams, TN
How can I add the table to my EFILive to change the firing order for a LB7?
bluessmax
Tabasco Injected!
Nov 4, 2010
1,151
Lake Charles, la
Unless efilive makes it public it likely won't happen... I'll see if I get a chance to find it in lb7/LLY. Haven't looked in it yet. I'm familiar with Bosch at this point but the Delphi I have not dug too much. Should be easy though in comparison to Bosch.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
This would be awesome!!
DPC
323
Adams, TN
Have you had a chance to mess with the LB7/LLYs? Thanks.
DMAX497
Sep 27, 2012
398
Utah
With the new wiring of the harnessing the lbz. Which cylinder would read for each injector off a scanner? Would they switch because of the re wiring?
Which cylinder is which now because of the AF cam?
Thank!!!
