I got an Airdog lift pump to put in sometime on my 2003 GMC. I have a couple leaks in the lines at my fuel cooler.
1-Will the cooler be needed when I install the lift pump?
2-Do I run a rubber line from the lift pump to the quick connect connection at the valve cover feeding the injection pump?
3-Can I run a new return line in rubber to the tank from the injection pump or would I be better off to get new hard lines and put them on when I install the lift pump?
Sorry for the newbie questions but I'm learning
