So here's the story.
A Month ago my trans lines started leaking. Local shop swapped the lines. Somehow my trans "blew up" last week. P700 code, only 4th and reverse worked. Trans temp was low 100's and never went over 200 on the limp home. Same shop said fluid was smoked and a lot of shavings in filter. They Did a flush and its working fine but they said in on borrowed time. They don't rebuild allisons but the owner and GM both have lml's.
I'm not going to lie, I drive the truck like a race car all the time. I'm on a moonshine 100hp tune, trans has 130k on it. I bought the truck with 100k on it and only drive 15 k a year. I figured it was gonna blow, but it's a little bit of a coincidence.
I have 3 questions.
1. Is trans shot?
2. Is it possible they helped it get there
3. If the l5p has another 50hp and 150tq stock. And the trans is the same as it was. How will it hold up with a tune?
The reasons for my questions are because I don't know if I should spend the money on a new truck or build the one I have.
If I get a new truck, I'm sure I will get it tuned and it's a lot easier to start down the rabbit hole on a used cheap truck then it would be to start with a $70,000 brand-new truck.
In other words, I will have this truck paid off in a year and can use the $10,000 I would put down on a new truck to modify this one, or I can put $10,000 down on a new truck and have double the payment I have now.
Thanks in advance for the help.
I have 3 questions.
1. Is trans shot?
