Has anyone successfully programmed injector trim codes on a L5P with an Hp tuners ecm? I have a friend's truck that was taken to a shop for a misfire and an injector was replaced and a snap on used to change the trim codes, but they all went to zeros and now will not allow it to be programmed. I'm not sure if this is because of the Hp tuners ecm or does an MDI II need to be used to correctly program the injector trim codes. Trucks far away from me or I would hook up my MDI and give it a try.
