any other issues??? smoke? rough idle??[/QUOTE
nope no smoke, starts to knock then I give it a little throttle and it goes away...
My truck has started knocking... possibly fuel related?
i thought for the longest time i had a injector or fuel issue..knocked when cold, no smoke....it was an exhaust leak....happened again this year when my up pipe bellows cracked
did you figure it out NickMy truck has started knocking... possibly fuel related?
Check you rail pressure des vs act. If not does it knock on decel?
Check your rail pressure when it doing it des vs act.
Ya my idle PSI is 10,000 it is a tuning issue no big deal.
