2005 ccsb lly. Sounds like something hitting the body? Idk how to explain it. Could it be a body mount? If so what do i do about it. Thanks
It kinda sounds like its coming from the firewallish area. Is it easy to replace the body mount bushing? Ill check the others that you listed as well. Just the body mount bushing sounds like the biggest pain in the rear. I have bilstine 5100 series shocks to go on it. And also could a bad cv axle cause it? I have grease coming out of the boot on that side but didnt think it would cause a problem with it?I've run into two things that cause this. One was worn out brake caliper slides and bolts, the other was bad cab mounts. If it's the sound I'm thinking of I'd go with the brake parts. I had a loose shock (missing the upper rubber bushings) do this once too but that one isn't very common I don't believe.
There is a large assortment of bushings in the suspension and diff mounts that I have been told can cause it too. Things to check I suppose.
I can trySee if you can get a good sound clip of it to post... That could help members here help you.
Ah yes. Been a long time since I have heard that one but entirely possible.Intermediate Steering shaft ? Very very common
How do o check this?Intermediate Steering shaft ? Very very common
I tried to get a vid but when i was trying it wouldn't make the noise or all you would hear is exhaust
Im not sure. Im replacing the exhaust this Friday though. It sounds like its coming from the front driver side though.Speaking of exhaust how are all the hangers??? The exhaust could be banging around...
