I had earlier posted I had a Smokey LLY. I took the truck to the Stealership and they told me I need to replace my right bank injectors. so I did. I don't have any smoke. but I have a Knock at about 1/4 throttle that is loud and it sputters when the truck warms up some. All sputtering and knocking go away at full throttle and truck goes quite. The Sputtering isn't bad you can feel just a little bit of hesitation kind of like light bumps.
I don't have full faith in the mechanic that worked on it and I wonder if he Mucked something up. I don't know if this sounds familiar to anyone. The truck doesn't always knock. at no throttle nothing and at half to full all I really hear is turbo, but somewhere around 1/4 throttle just normal driving loud knock. I am about to throw the towel in on the truck. I have no codes other than P0741 and P0700. The transmission is shifting great though so I am scratching my head on that.. any help with that would be great too. I left the truck with the mechanic and he replaced the passenger side with the good ones. I showed up to pick up my truck and it knocked really bad still and I noticed he hadn't touched the side that was bad. Plus there was a snap sound. I was told that was because of an O-ring that was wrong? No idea that was the mechanic. so he took my old good ones out and put them in the drivers side. I picked the truck up and left and I had no power. a big wiring harness was not plugged so I zip tied that back on because the clips were broke. I took off and I blew the bottom hose out of my intercooler for the turbo. stuck it back on and tightened it. then took off and the top end of that hose popped off right before the intake.. so I put that on and tightened it. I noticed my truck said low coolant after beating my head against the wall and bleeding my system I noticed the sensor was unplugged. I thought I was leaking the fluid. I wasn't... so now... this is where I am..
I also have a second problem. I didn't have heat which I figured out. I thought I had a plugged heater core but I could blow water through it no problem. figured out the heater for winter that heated the radiator fluid when plugged out and a ball valve in it that was stuck.. Now I have great heat in the truck. but if I turn it over to defrost it will switch to floor defrost not full defrost and I can't change it to anything else. If I turn the nob back to vent then nothing.. If turn the truck off and right back on. It will blow out the vents.. Any ideas?
Thanks a head of time for your help. I hope it makes sense.. I am at lunch and typing as fast as I can..
