Key install without special tools?
Max Power
Mar 16, 2007
72
Manitoba
Is it possible to change keys without the special torsion bar unloading tool? I want to do this but I don't want to buy $150 tool to do it once.
Alligator
Nov 9, 2006
1,919
N. Idaho
You can use a standard c clamp, just remove the end plate so the ball goes into the socket on the key. You just won't have the tab that locks the c clamp into the x-member.
Max Power
Mar 16, 2007
72
Manitoba
I can't quite picture what you are talking about but I have never had anything to do with torsion bars either.
How much force is on the torsion bar with the bolt backed off all the way? I guess I don't really know what to expect since I have never done it before.
Alligator
Nov 9, 2006
1,919
N. Idaho
I don't know how much pressure is on the unloading tool? All I know is, it takes every bit of what the 1/2" impact has to spin the bolt up high enough to get the stop out. The way I am describing is red neck at best, and could inflict serious injury if it let go. I was just telling you how it has been done before, and not my recommended way of doing things. IMO, the buck fifty is well worth the $$$ spent to keep my ass out of the hospital. I wouldn't want to do it with a c clamp again...
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
it depends, there is enough that ready lift keys backed all the way off and truck jacked in air bent my 12" c-clamp and i didnt even budge the key. unloading tool is safest (i knocked my self unconscious last week trying to get ready lift keys out of a friends truck, 1 1/4" wrench i was using for leverage on c-clamp slipped and almost lost my left eye) LOL, I live and learn, usually the hard way. regular keys are probably much easier to get in/out
Corrod95
Dec 28, 2008
5
Illinois
ok this is easy. I just did it myself. go to the auto parts store got mine at advance auto. get a 2 armed puller medium size costs abot $25 if they have a real cheap one for like $6 don't waste your money. I broke one of those. put the arms up over the torsion bar cross member, you will have to hold them there with one hand then start tightning with the point of the puller in the torsion key dimple once you get it good and tight it will hold... then just start cranking on it... make sure you have the front of the truck jacked up. sounds tough but not too bad. my torsion bars had to be heated a little to get the out of the keys along with a 2lb hammer and a solid bar for a punch.. I could send you a pic of my puller if you want. the puller will work alot better than a c clamp. the one I have you put a socket on so you can use a 1/2 drive ratchet:D
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
Don't use a C clamp. I have done it a few times but I wouldn't recomend it. It's a hospital trip waiting to happen. I got a big C clamp too.
Can you rent one of the unloader tools from a auto parts store? Never thought of that untill now:rofl:
Alligator
Nov 9, 2006
1,919
N. Idaho
I prefaced my post like that too. He just asked for a cheap way, not safe...:angel:
z79outlaw
793
37
Salem WI
I dont like using C-clamps almost took my self out a few times have at least 3 or 4 destroed C-clamps around from it, from bending the threaded part or bending the forged C- section. I'm to cheap to buy the tool also but another thing that works that I've used occasionally it a 2 ton bottle jack and some cribbing to get the jack up high enough. Its another way of getting it done I guess, but I in no way accept liability for any injuries occured.:cruch:
Alligator
Nov 9, 2006
1,919
N. Idaho
Another good reason to buy the right too for the job...
