I've got a Tink Tink!
Dmax1548
Mar 30, 2014
15
For the past two weeks I have been seeing white smoke out the exhaust and strong raw fuel smell. Typical injector issue was my thought and have been saving pennies for a injector change. Buy checked the oil the other day and it was lower than I had ever seen it but still on the stick. Topped it off and 3 days later (today) I checked the oil again and its low once again.
I let the truck idle and opened the oil cap to see if I saw smoke and I see constant faint smoke coming up the filler neck and also hear a decently loud "tink tink tink" consistent with idle speed.
Also have a lot more smoke today. Blackish at stop and white/blueish under throttle.
Could I be in for a lot more than injectors?
Dmax1548
Mar 30, 2014
15
I have only seen/ smelled the symptoms for maybe 5k or less. But I have seen more sut on my bumper over the last 6 months.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
That tink is totally normal. I have thread on hear about the same noise from like a year ago. I think its because the cam and cp3 are gear driven. A little smoke is normal too.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
To condense my post earlier. The tink is totally normal, find another duramax and listen too it, the smoke is bad injectors, put a new set in and run strong for another 207,000!
Dmax1548
Mar 30, 2014
15
I have a guy here locally that has some for $1200. That's the cheapest I can find them and still tight on budget.
Sent from my Galaxy Nexus using Tapatalk
