Yea go ahead Tom. I would buy one from someone for cheap still.Since it looks like you found a cam, is it ok if I move this into the "Things with Spark Plugs" section for the tech?
I checked all of them and they are still great shape. Holds the lifters as intended. The two I've done were both like this one. No evidence of the lifter turning sideways or roller frozen. But yet the cam lobe wore off.. ..How does The failed lifter feel in the plastic tray it came out of?
Thanks Issac.Yea go ahead Tom. I would buy one from someone for cheap still.
Sent from my SM-G960U using Tapatalk
Half tons have afm. Their complex lifters are notorious for going bad, causing misfiring. But they dont typically eat cams in that scenarioLS in general eat them. Guy down the road had a 2015 half ton / 5.3 with under 40K miles crap a couple lifters
Only trouble we've had with the LT so far is a bad variable oil pump, and a leaking hi pressure fuel pump.Here we see quite a bit of afm lifters failed with damaged rollers that eat the cam lobe. It’s been more pronounced in the new LT engine group than LS.
How much?I just pulled a cam out of another L92. It's a tiny bit bigger than an L96 cam. You need or want it?
How much?
Suits me. Appreciate that josh. I'll pm youI'm just gonna throw it away. You cover shipping, and you can have it.
