LBZ: Is this temp correct?
racingctf14
Oct 3, 2012
17
Now that it is cold outside(20-30 degrees) my truck will not get up to the same temp that it used to. Does that mean the thermostat is stuck open? Here is a pic of the temp gauge at its warmest point during normal driving. ImageUploadedByTapatalk1355908474.654392.jpg
Thanks in advance
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Does it fluctuate,put the truck in manual and shift high get the RPM up hence the ECT up.
Is you coolant tank fluid level where it is suppose to be
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I took my truck into the cold today. ~40*
Letting off the throttle coasting downhill my temps rapidly dropped to 185* like yours in that picture.
They rise to 210 in 30seconds or so if i get on it.
racingctf14
Oct 3, 2012
17
It's doesn't fluctuate at all unless I start climbing a hill and then it will get up to just under 210. I will have to check the coolant in the morning.
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
265,000 combined miles between My LLY and LBZ tells me your temperature is right where it should be without a winter front in 20-30* outside temps.:thumb:
