Is this normal?
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
Ok i installed the lb7 cp3 with lbz reg. changed all the fuel reg. B1010 tables
1550
1504
1460
1420
1387
1375
1360
1350
1340
1330
1315
1302
1296
1190
1104
1030
870
690
wich idles fine now .But i had to turn my fuel pump down because what happens is when i start it idleing its like 7,000 psi but start climbing to 11,000 SO like i said i turned the airdog down a bit 8psi i had it at 10psi initially ,so now it holds at around 7200 psi but if im in a 200hp tune or max effort when WOT my airdog wont keep up it drops to 2psi if im in 85hp or 150hp it holds at like 5psi WOT.??? so is this normal or should i change B1010 table again get it to about 6000 psi then turn up the pump some?:confused:
13,736
805
You can start raising the values at the top until the fuel pressure is down where you want it with the lift pump turned up.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
Thanx Josh , Do you mean the top 3 or 4 ? And what should i change them too? im afraid to screww something up...im still new to this if you give me some #'s i can change it ,im just not sure how to do the math and figure it out for myself,Rob says 5% at a time is this true?And also would this be right to do example change 1550 to (1627)???:confused:
DPC
323
Adams, TN
Mine did the same until I changed the values. Here is what I am running, it idles around 5000.
1800
1648
1488
1326
1215
1159
1121
1088
1056
1020
1000
993
986
930
878
826
770
601
400
