His dumb ass logged it and it set the code while it was logging...but guess what the laptop was asleep!!! So no info
It's gotta be a wiring issue! either internal or between the trans connector and the tcm. Have you been able to log the fault happening??
What have you tried so far? Have you dropped the pan to see what was in there yet?? is the truck stalling??? What other sypthoms do you have besides the code??
i got that harness if you wanna try it captain dutshe!!! Check the pins in that main connector too! I had one pushed out and mine was doin some wacky shit!
Mine did the same thing work fine for a while then shift funny and throw different codes. The plugs that go in the Tcm and the Ficm "The one on the valve cover" they were dirty pulled them off and cleaned them with contact cleaner. Plugged them in and had not had a problem with it anymore.
I had a similar problem to what you are describing and it was the connector on the speed sensor on top of the tranny. It appeared to be fine but was broke and the pins weren't making connections all of the time. It would loose connection then set the codes.
