Truck clunks hard into drive or reverse. When in drive, after a little bit of throttle, it will kick into neutral and bar under D flashes.
At first had an E valve stuck code, dropped pan, moved E valve in/out a couple times, closed up and now E valve code is gone but still clunks into geear and kicks into neutral.
No Codes
Speed sensors were swapped with know good ones (not new).
NSBU was swapped with a used one, then again swapped with known good one from running truck.
Connections seem to all be golden including on valve body.
Correct amount of fluid.
Kinda at a loss where this issue might be. Seems electrical.
Any ideas anyone wants to throw at me???
Thanks guys.
No Codes
Thanks guys.
