the lml is 16:1, but the van engine is 16.8:1. Also, i had a conversation last wk with one of the engineers and he still thinks that the pistons will crack at twice the hp rating.all of the lml short block parts *should* interchange with all previous gen dmax short block parts...all of the basic dimensions stayed the same, so i see no reason why you couldnt try some lml pistons in a lb7/lly/lbz/lmm built motor and see how they hold up...
Cr is down a bit too on the lml, i think its now 16.0:1?? Or at least thats what some of the documents said....
hopefully! whats nice is they are 16:1 meaning no machining needed during buildsI know this is a million dollar question, but I would be plenty happy if they were as strong or stronger than LB7/LLY pistons...
anything is better than LBZ pistons.
But did he hold the same opinion of the LB7/LLY pistons ?the lml is 16:1, but the van engine is 16.8:1. Also, i had a conversation last wk with one of the engineers and he still thinks that the pistons will crack at twice the hp rating.
(400+-)x2 is still over 800. The LBZ aren't doing that.
i was informed this afternoon (by somebody who had pulled apart a lml) that lml pistons will not fit lbz rods without machining.
Theres the question.But would the piston/rod combo fit an LBZ crank ?
