So let me start by giving the basic info, '05 LLY 142k miles. Lately I've been having an issue with my truck where it will idle and run like crap....but only sometimes. To give an example, I drove it work the other night, ran like crap and I had to limp it there. Left work that morning, ran like a raped ape. Go to the store that afternoon, ran like crap. Ran it back home, no issues.
It won't throw the SES light and this all began shortly after I changed the fuel filter. I thought maybe it was pulling air in so I pulled the filter back off and found the o-ring was little too big so I put the old o-ring back in, which fit much better. Now, since I've owned the truck, I've only used AC Delco fuel filters but the place I buy from could no longer get them so I went with a Carquest HD. I can't imagine the fuel filter being the issue but I've seen dumber things.
Any ways, fixing the o-ring didn't help. So I scanned it for codes. Pulled a P1232, Injector 4 Output Circuit. Cleared it and looked online. Found a wire exposed by the alternator. Got that all fixed, still has an issue, again though, only sometimes. Sometimes it'll run like crap then clear up for a few miles and then run like crap again. Went kayaking, ran great going there. Coming back, ran like crap so I stopped by the parts store and pulled the codes. This time I got:
P0300, Multiple Misfire
P0301, Cylinder 1 Misfire
P0304, Cylinder 4 Misfire
P1223, 1226, 1229, 1232, 1235, 1238, 1241, 1244 (Output circuit for all injectors)
Cleared those codes and haven't seen what's come back yet. I've let the truck idle while I wiggled wires to see if anything changes and haven't found anything (and of course at that time it was idling like normal). I looked at the C107 connector and didn't find any exposed wires there either. I'm ordering a OBD connector so I can download TorquePro and look at things with my laptop. I am at the point where I'm ready to start removing stuff and pulling the whole wiring harness to go over every little thing. But before I go through the trouble, I wanted to get others opinions on what it could be. I'm starting to lean towards the FICM, but I've never had an issue with the truck till now. I even thought about putting the old fuel filter back on and see if things clear up.
Thanks you for any and all ideas
