intercoolers?
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
I've got the Spearco IC on my truck, but I do mostly all towing and no drag racing / sled pulling. The Spearco unit was good for a 2psi increase at the motor and about 150-200 deg. cooler EGT while towing. For me, it was a great mod. Not sure about a race-only truck though.
Where ya been???
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
all my testing to this point is via seat of the pants...I'm not fast enough to bother with sweating the details, no disrespect intended.
I have had a stocker then Banks and currently run a water to air cooler. The Banks allowed the system to recover a little faster and spin a little easier, I belive through less restriction. The Banks IC had larger IC pipes IIRC as well.
This makes me think, had i tuned to it, i could have gained some HP through flow and a cooler intake charge. IIRC (been over a year) the biggest problem as i remember was the IC is behind the radiator, condensor and trans cooler... it saw hot air and is a big aluminum heat sink in itself.
If money and fab isn't an issue water to air is the way. The air can go straight in and straight out, cooler medium with less pressure drop. At this point my truck, with water to air, grabs RPM/better throttle response than it ever did with Banks or the stocker. If this truly works i should be able to make more power with less effort.
Good luck with whatever you decide. :)
James and others I thankyou for the reply:) Fact is this thread is very old and I am going with a w/a IC eventually and for the purpose of my truck I think it will work.
Upgrading the air to air on a race truck doesnt seem cost/hp worth it JMHO.
If it was a DD then I would never go with a W/A and would probably go with a Spearco or Banks.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
wonder if the w/a would work with a dailey driver :confused:
dmaxlover
Mar 17, 2007
453
WI
Banks told me that I could run 10% more fuel and keep the original egt's.
I also seen a 2psi increase in boost post IC.
