Question: Intake bridge questions
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Bolt pattern is the same side to side but different top to bottom! The LB7 is shorter top to bottom. The runners are also different due to different bolt pattern/size.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
LBZ+ intake manifolds (logs that bolt on the head) have a larger opening than LB7/LLY, so they are not interchangeable. The LBZ manifolds are better.
The LBZ Y-bridge (neck?) on pickups have a two piece that is fairly restrictive but the Kodiaks have a 1 piece that is less restrictive, IIRC. Don't know what you would have move to around to bolt it on, but it should bolt to the manifolds.
13,696
747
You can use a van bridge. They're very similar to an LB7 bridge and will bolt up to your intake manifolds.
