installed steering shaft, still have the annoying sounds
weazel
261
Mason, TX
ok, so i threw in a new steering intermediate shaft in the 05 last night in hopes that it would take care of the vibration/ thudding sounds that come from the steering wheel while going over say a rough road or something. it didnt solve the issue.. i have replaced the ball joints on the passenger side, but not the driver side yet.
what would yalls opinion be? could it still be the bad ball joints on the drivers side causing this? or is there another steering shaft i need to check out?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
There is a bearing in the end if the steering column that goes bad ilk seen I can find the article was reading.A Chevy tech replaced his shaft and it kept rattling so he chased it down to this bearing and replaced it and now that's all he does instead of replacing the shaft he does the bearing to all of them.
Duramax5
duramax freak
Sep 15, 2011
417
West Texas
My buddy works for gm and he fixed mine.underneath the dash there's a weird lookin ring that tightens up around the shaft and they slowly get loose. Take a little air hammer/chisel and tighten the sh*t out of it. Bet it will fix it:thumb:
paint94979
Beer Nazi
Sep 18, 2006
11,715
Hmmm interesting mine has rattled and clunked for years and I'm just now at the point of getting annoyed with it lol. So ill need to buy this bearing and an intermediate shaft?
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
A lot of lower steering column bearings can be 'fixed' by tightening a regular hose clamp around the housing where the lower bearing is at.
weazel
261
Mason, TX
Did you check the idler and pittman arms real good for any wear?
No, haven't checked those yet. Will take a look when I go to do the ball joints.
Thanks for the info and the article, I'll crawl under the dash and take a look at that joint that's being talked about...
weazel
261
Mason, TX
Guys thanks for the help! I was able to find that the shaft was still loose from that white coupling where the shaft bolts to. I used a hose clamp and tightened it down, took it for a drive, and no more annoying clunk! Man wish I woulda known before, would have saved me 80 bucks LOL!
quinton
1,883
Granbury Tx.
Should have texted me man! Lol. I tell you I'm building my motor?
