Installed injectors and pump!
02greysixer
1,829
North Central FL
Edge reads in thousands. So 0.2kpsi is 200psi. 0.3-0.4kpsi is only 3-400 psi. Nowhere near enough to run the truck. Assuming your Fass is working and you have constant fuel supply, there's either a high pressure leak somewhere or you have a faulty new part(s)
As said it doesn't take much of a high pressure leak to keep rail pressure from building. If all your lines are tight and dry time to do a bottle test on the fprv, if it's not dumping do a return test on injectors
Sent from my SAMSUNG-SM-G870A using Tapatalk
lly_kid
Jan 16, 2015
13
West jordan, UT
I have the race valve in place of the fprv
lly_kid
Jan 16, 2015
13
West jordan, UT
Installed at the same time as everything else? If so still check it. If it's old and the truck ran fine with it disregard.
Yeah its old. I'll go through and check all the lines to the injectors, but I tightened them ad tight as possible
lly_kid
Jan 16, 2015
13
West jordan, UT
I feel dumb now. I went and checked the driver side fuel lines I tightened them all and it fired right up. Thanks everyone for the help!
Awenta
4,090
CT
As dumb as you feel it's still better than replacing new parts!
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
Its always something dumb. When I got my LLY back together after new heads, spent a week trying to get it to run right, I had the cp3 hooked to the baro sensor and the ecm plugs for the two hooked into itself.
02greysixer
1,829
North Central FL
Yeah don't feel bad. I work on them everyday and still forget to tighten lines sometimes. It really sucks to do stupid shit like that on lml cp4 high pressure lines.
