LLY: injectors, what do you do?
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
Just surfing the net looking at several shops that sell injectors..
My question...I got on exergy's site..why is there such a big price difference between buying(say 60% overs) at a shop vs just sending them to exergy to have them done yourself? Aside from the downtime I guess...am I missing something or maybe I'm reading their price schedule wrong??
03spoolindmax
Nov 9, 2011
674
Mi
Exergy quoted me right around $1650 to send my injectors to them and flow them to 60% over. That's hoping mine are still good.
If you buy new injectors from them you don't get charged the initial cleaning and inspection fee.
03spoolindmax
Nov 9, 2011
674
Mi
http://www.exergyperformance.com/docs/exergy_services.pdf
Step 1 $50 x 8 = $400
Step 2 $90(I believe per injector but could be wrong)
Step 3 whatever size over you decide to go
Step 4 $728 for used or $546 for new/ reman
Step 5 is for any addition cost
Add that together and that's what it'll be. It's confusing to read at first but it'll come to you once you understand it
Or you could just call them and ask. That's what I ended up doing to make sure.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
mine were right in that ballpark too, the price difference is usually the fact that you're buying New injectors from someone else vs reworking the injectors you already have. and most other places don't flow balance their injectors either...
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
This..I read over it and was comparing prices to shops...looks like its a better way to go for sure! What's the turn around on 8 honed to 60%?
Dirtymaxx03
3,109
It gets expensive when you do it "the right way" and buy Bosch injectors new, then send them to be punched and flowed by exergy.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Damn their price went up. A few years ago Gregg quoted me 1300$ and from everyone else it was 1500$. Inflation sure is a bitch
03spoolindmax
Nov 9, 2011
674
Mi
Well thanks for making me feel better about the price :roflmao:
Good thing my lly injectors have around 75k on them. Hopefully they're good when I send them in to get them punched out to 100% over.
Harbin_22
3,858
Southern Indiana
Has anybody ever just had tips done and swapped out tips yourself? I did my first set myself from dipper and were fine and still being used in another truck today. Would be a lot cheaper to just swap the tips
03spoolindmax
Nov 9, 2011
674
Mi
I'm sure lots of guys have. I had a set of 75% II tips I was going to use but decided to sell them. With as much as I'm putting into this motor build. I'd rather have mine gone over and know exactly what they flow.
Knowing that fueling is one of the biggest factors in making power in a diesel. I'd hate to swap tips and have something go wrong and crack a piston.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,198
362
At Da Beach
I tried it on an LBZ at my buddies request with questionable results. The truck hazes like a mofo...
onebaddmaxxx
1,212
Cecil County Md
lb7s are a pain to just do nozzle swaps because you risk dirt/rust coming out of the lines when you remove them. lb7 tips are a lot easier to swap because you don't worry about loosing the puck
iv swapped lots of nozzles from George and the key to lly-lmm is NOT losing the puck. To pull the injector up slowly watch that the puck stays in the body. If you lose it, its gone forever and the injector runs wide open. they are also 1/64th the size of a penny. The first set you can be nervous about but once you get it your good!
quinton
1,883
Granbury Tx.
I swapped tips. Stock to 80% overs from extrude. Run good but little smokey.
country lbz
Feb 28, 2013
60
Indiana
I had this done^ with great results so far. Exergy 60's on my stock bodies. Then sent to Scheid to be flow tested and have return rates checked.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Why pay to have your injectors tested? If they hone them all and then find a bad one when balancing wont they just install the tip on a new injector finish balancing and charge you for the new one?
