Had them done at dealer about 50000 km ago. and now have cyl 3 at 4.2+ in park warm. Is 50000 all these last? If so i better get another truck....
You have an 03, sell the LB7 and drop an LLY in it!
Do the GM upper cylinder cleaner on the injectors it should cut the injectors+, down to least 1/2 of what they are.I've got+6 brought down to +2 before.Do you have a good lift pump with filters?The lift pumps i build i use a 3 Micron water Sep then the pump then a 2 Micron deep filter,they filter way better then the stock filter and i eliminate the under hood filter.
Yeah when we do it we use a gallon and pour the total contents of the cleaner in and fill the rest with diesel and run the return line back into the gallon jug and let the truck idle for a few hours and it cleans them up nicely most of the time.I told my buddy to this on his and it worked really well.
We just buy it at the dealer its GM Upper cylinder cleaner i think its 19 bucks and it really does work.What cleaner chemicals u using,
thanks for the input, it has now dropped to 1.9 on my edge. I have no idea what is going on. but i will keep my eye on it
Did you check them on a stock tune at operating temp?
My last set did something like that. had a quarter tank of fuel left so i threw in a quart of diesel kleen and a quart of 2 stroke oil. they dropped right back to 2.0.
they were still on their way out though. Guy tested them and shot me some pics of what happens to the seat/ball of the older non chromed style. looks just like someone took the edge of a file and ran it right through the hole and ball tip
