I've been looking for some nozzles for the lbz. but dang even their expensive
What size over are you looking to go ?
X2I see injectors fail on all of the duramax engines, the key to injector life is keeping water out of the fuel and good filtration. The later injectors for the lb7 seem to have evened out the playing field quite a bit. As far as I'm concerned you guys should keep buying LLY, lbz and LMM trucks so it keeps the lb7 prices down for us guys who aren't scared
Darryl and Henry will hook you up on the cheap for sureIf you go with a lb7 try to get one that had them replaced by the dealer already. If you do get a lb7 I'm a lot cheaper then the prices you posted for injectors heck I can send you ones 30% or biggier for the prices you posted. With a 12 month unlimited mileage warranty.You will have to put out for a core charge at first but you get that back.
This is money well spentIf you get an Lb7 take it to a good dealership or diesel shop before you buy it and have the fuel system all checked out. That way you'll know if you're going to need to do them soon or not. It's cheap insurance really, if I'd have done that I'd have gotten my truck for less than half what I paid for it.
Sint frum tha orijinul smert fone
Henry can hook you up im getting injectors and 60 overs in a couple weeksI've been looking for some nozzles for the lbz. but dang even their expensive
well i figured if i was gonna get some id go 100% i don't really see why i should go any smaller lolWhat size over are you looking to go ?
And I have to ask what other supporting mods do you have? Do you have twin cp3's a large single turbo or big twins or a triple turbo kit on there. Also do you have a built motor ?
Tom im honestly not a believer in that... absolutely some LBZ's run big power and live where others aren't so lucky. Not because I have one but IMHO its kinda hard to look at LLY's as being inferior to the LBZ's. My truck has made good power for a long time and as far as I can tell to no ill effect.
