LB7: Injector Prices
1,839
Buy Bosch-rebuilts and you should be ok. I believe Henry has them, Guy may too. I have heard good things about Exergy Engineering.
Go with other rebuilders like PennDiesel at your own risk.
SparkZ03DMAX
Nov 16, 2009
866
North Carolina
Ok so here's the deal, I know you guys have been through this before.
The truck will run fine with no symtoms for a week but then like two weeks later it doesnt run right. It has a terrible injector knock on the passenger side when the truck is in park or neutral. Sometimes once its in drive or gear like if I'm at a light or stop sign holding the brakes, it will lightly haze white smoke. Obviously this is injector(s). Sometimes it will do a small lope while in gear.
So based on yall's experience does it sound like have one or two bad injectors or do I have MANY injectors out?
Can u give me some advice on what to do until I find a way of getting money to replace them? I'm putting in 2 stroke oil and Diesel Kleen whenever I feel that it needs it.
