Injector opinions needed
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
So Guy's are $1500 for a set of 8 tested nozzles installed in your own cores, correct?
Not just 8 tested nozzles. Guy takes in your injectors, the tips are enlarged to your specs, tested to be sure they flow equal, then re-installled on your injector bodies, the entire injector is then tested at 26,000 PSI and real world PW values. If they don't flow correctly the shop he works with can actual do calibrating on the injector itself. When you get them back you will know that all 8 flow within a very close percentage of each other as an assembly, not just that the tips flow equally.
05lly2500hd
(903)293-6026
Feb 16, 2008
473
45
Texarkana, TX
Yea I understand that.just making sure it wasn't $1500 each....lol. If I knew some sets were only 500 I'd bought them already. Think ill go with guys
