Going to have to go to a bigger nozzle now that the twins are on. probably 60% overs. Who makes a reliable, consistant nozzle?
Kelly
Kelly
Im pretty sure Dippers injectors are balanced out.
they are all suppose to be "balanced" some guys have there heads up their asses and some know what they are doing. Ask othrgrl about non flow tested injectors. MELTED! Pistons.
George flows them before and after , I dont think the pressure is near what Guy is using though .
Thats the thing not many shops out there can reliably test to 190 mPa and further...I saw a flow sheet of some 05 CR tips from Industrial Injection they were so far out of wack some were 15%-25% higher or lower. The truck ran like shit and the injectors were the culprit. If you have to ask me a shop like industrial injecting there parts should be very reliable and precise. Obviously there will be some variation. That is why i would seriously explore Guy's... you send your whole injector to him and he tests each injector not just the tips using a totally different injector.
X2 the have been track tested. IIRC rob picked up .3 by running a set of George's injectors.
so you're suggesting george doesnt know what hes doing?
So Guy's are $1500 for a set of 8 tested nozzles installed in your own cores, correct?if you have 1500$ i'd get Guy's that flow sheet is a damn nice insurance. George's injectors for a 1/3 of the price a good option as well
