injector knock????
maddmax95
Feb 1, 2016
27
I got what I thought was a injector knock. I was running late for work and got on it after a stop sign and didn't hear anything but looked back and saw a ton of smoke as well as a loud knocking coming from the engine. So I pulled the injector eletrical connecter on the #7 and #2 being as they are the common problem childs. The knock still occurred after pulling #7 but when I pulled #2 the knock would go at crank but would leave within 2 or 3 seconds. So I changed the #2 injector and it looked rough a lot of build up around the nozzle. After installing the reman injector I still have the knock and I can't afford to put it in the shop nor afford another injector I need yells advice to try and knock this out as quickly as I can so I can get back to work thanks in advance.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,224
370
At Da Beach
Need a cumputer with efi live or a good scan tool. The lly is a bitch to figure out which injector is bad though. Have you checked the ficm harness really closely?
maddmax95
Feb 1, 2016
27
I've checked the balance rates but all I got on it is when the stroke was 0s across the bored until the knock came then they would all jump to 20 17 -13 just ridiculous numbers on all 8 of them.
maddmax95
Feb 1, 2016
27
As for lifting baxk out of the head I've had that happen to me before and it just sounded like I was losing compression. Just isn't the same
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Check the injector harness where it is routed around the alternator bracket. Inspect closely for worn insulation, broken wires or wires rubbed through and shorted to ground. Very common issue for LLYs.
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
This doesn't sound right. What were you checking balance rates with?
maddmax95
Feb 1, 2016
27
I checked them again today after work while in park my rates are 0 across the board but put it in drive it fluctuates from 0 to highest i saw was 13 on all 8 injectors and will a bad harness cause a bad injector knock?
maddmax95
Feb 1, 2016
27
I was checking it with edge cts 2. I have a efi autocal at the house just not sure on how to use it just used it to upload my tunes when I got it
NC-smokinlmm
May 29, 2011
5,224
370
At Da Beach
Sounds like a bad ficm...
Bc obviously you have already checked the harness if you can't respond to people trying to help you...
maddmax95
Feb 1, 2016
27
Yes I checked the harness around the alternator and all injectors and didn't see any lose or rubbed wires the wire looms is still completely intact
maddmax95
Feb 1, 2016
27
Ok so is pulling the harness simple as it looks and should i replace it? And i did the balance rates again today and it is zeroed out in park and drive it's 0-13 on all 8. So I have 2 more questions. I've been reading on rebuilding the injectors myself I saw a place that made a kit with all the O rings and what not for the injectors plus tips. Would that be a viable option cause I really need to replace all 8 and want to go ahead and do 30 over if I do but like I said earlier I don't really have the extra money to spend at the moment for a whole set. So would rebuilding them myself be a option at all? If not I got a offer on the truck today I will probably end up cutting ties with my truck if I can't rebuild myself?
Brent@LDS
651
Wisconsin
We have some really good prices here on our Brand New Bosch LLY injectors. Rebuilding them yourself will not be successful. Takes a lot of proper tools, test bench, clean area, and expertize.
