I got what I thought was a injector knock. I was running late for work and got on it after a stop sign and didn't hear anything but looked back and saw a ton of smoke as well as a loud knocking coming from the engine. So I pulled the injector eletrical connecter on the #7 and #2 being as they are the common problem childs. The knock still occurred after pulling #7 but when I pulled #2 the knock would go at crank but would leave within 2 or 3 seconds. So I changed the #2 injector and it looked rough a lot of build up around the nozzle. After installing the reman injector I still have the knock and I can't afford to put it in the shop nor afford another injector I need yells advice to try and knock this out as quickly as I can so I can get back to work thanks in advance.
