Injector hold down bolts stretch?
MSEngineering
EnvoyMax
Sep 7, 2009
27
Orlando FL.
When it is dripping off the end of the bolt and displacing the air in the cavity with a non-compressible fluid, that is when you have used too much.
As far as how it alters friction levels, you are correct. Which is why I said more isn't necessarily better. It is entirely possible to achieve positive thread engagement before achieving proper hold down torque if there is fluid trapped in the bottom of a blind hole. Your torque wrench may read it is torqued, but the force on the surface area the bolt is holding down may not reach spec.
Really... air squeezes out and so does the lubricant.
Male and female threads aren't air tight, if this was true we wouldn't need seals and plugs and or flared mating surfaces (ehem injector fittings) or AN fittings around fasteners that block pressurized and pass pressurized fluid through them, we would just screw them together and be done with it.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
This makes no sense, maybe that's why people call mechanics ''parts changers'' and not engineers.
I have a question for you. How can you use ''too much'' lube?
Maybe that's why engineers aren't called mechanics.., they can't understand unless it's written on paper, and even then couldn't physically perform the task they "engineered" :cool2:
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Funny ^^^:rofl: might want to re think that statement..
MSEngineering
EnvoyMax
Sep 7, 2009
27
Orlando FL.
I'm not going to stray off subject, so bringing up something else is just contrary. I'm specifically talking about the fastener threads.
''they can't understand unless it's written on paper, and even then couldn't physically perform the task they "engineered"''
If you really think that's how they all work.....
9,905
151
Wow. Really?? Spoken like a true engineer. Try to think outside the box for a second as obviously you don't have the hands on experience to understand the problem here.
First off tapered threads such as NPT/MPT obviously are different as full thread engagement is the sealing surface. Hence the reason for thread tape/pipe dope or other lubricants to keep the threads from galling when they get tightened. Other methods of sealing as you stated like flared, AN,JIC have straight threads and use a tapered surface while others with straight thread will use a sealing medium of some sort like an O-ring such as the ones used in ORF or ORB fittings.
But we are talking about straight threads here with a bolt. Technically yes there is no positive seal between the threads until they reach the point of positive thread engagement. But there are conditions where this can happen.
For one, it is entirely possible to thread a bolt in fast enough i.e. via the use of an impact gun, that it will not allow the fluid to get past the threads before getting full thread engagement due to trapped fluid or from the head of the capscrew tightening against the surface it is holding down. The heavier the fluid, the more likely this will happen. This can easily and most commonly happen in high TPI fasteners or long threaded bolts with minimal clearance between the bottom of the bolt and the bottom of the hole. Also if the threads have not been adequately cleaned they can also restrict the flow of the fluid trapping it both between the threads and below. Over time, they can slowly migrate up past the threads resulting in a loose bolt.
With air it doesn't matter as much as A) it can evacuate the cavity much faster than a fluid and B) air is compressible hence the reason generally this never happens with a straight thread capscrew or stud.
I personally have had this happen to myself when I was first starting to use air tools. After discovering this problem, cleaning out all blind holes and careful use of lubricants and loctite alleviated this issue for me. It came with hands on experience, education and common sense. Hopefully I explained this clearly enough for you to picture what can happen.
If only I could count the times an "engineered" procedure thought up in front of a computer was not practical or even possible in the real world. And most of the time you could argue with them until you were blue in the face and they would stand by it blaming you until they actually went out into the real world and tried to do it. Granted, a different design or procedure eventually fixed the issue shortly after, but sometimes trying to get them to see things from a real world perspective was the only way.
I've also worked hand in hand with several engineers over the years putting their thoughts on paper into real world application and the good ones were always the ones that took input from those with experience actually doing it and/or stood next to you while you did it to monitor the procedure.
Sorry not to badmouth all engineers. Just like those of us actually performing the work you designed there are good and bad at both. I know there are some really smart ones on this site, I try not to offend you all......
9,905
151
These guys are out there however:D
MSEngineering
EnvoyMax
Sep 7, 2009
27
Orlando FL.
Yep, 'I don't have' the hands on experience you can determine that from miles and miles away, like the taking impact guns to anything on a cylinder head is experience I definitely wouldn't have ! lol....
That made me smile, okay I'm done here.
9,905
151
Well your response sure made it sound like you don't. I guess in your perfect world stuff like that would never ever happen though meaning it never can right?
13,746
819
I'd really like to hear exactly what this statement is supposed to mean. As a mechanic, it seems highly offensive to me at first glance, but I'm willing to give you the benefit of the doubt until I hear your explanation.
