Injector hold down bolts stretch?
thunder550
1,176
Phoenix, AZ
When I get into higher boost levels I start to get ticking coming from one of the cylinders. I'm 99.9% sure it's air getting past the copper injector seats. I tightened them a bit and now it takes more pressure to make the sound, but still does it. Do the factory bolts stretch? What can I do to get more seat pressure on the injectors to help them seal better?
03_DMAX
Aug 15, 2010
124
Studs/Billet hold downs are not needed at your power level. Get new oem factory bolts and torque to spec. Problem solved....
bml2200
256
IL
Make sure there isn't a copper washer stuck in the bore as well. I've snapped a hold down bolt while torquing before, it sucks.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I re-torqued then 2x and was fine and like others cleaned the threads and lubed them upon installation
The 3rd time was the "stretch point" for me, I wound up torquing them way past the factory spec to get them to seal under boosted cylinder pressure...
New ones will serve you well, no need for the SoCal hold downs...
But they are cool
:thumb:
thunder550
1,176
Phoenix, AZ
Everything was really clean, heads had just come back from the machine shop and looked brand new. I cleaned the crap out of the valve covers too before reassembling. I think the new bolts will help :)
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Make sure the injector hold down pad is in the valve cover, I've seen that a few times. We used stock bolts at 85psi boost all last season without issue. This season we lifted an injector and killed a head (more boost), luckily stock heads are cheap and easy to find:spit:.
DMAX497
Sep 27, 2012
398
Utah
Blew one of mine out this year... Tick way loud and fuel spitting out. The bolt stretched... So hell with it and have billett hold downs now.
5,818
make sure its not a boost leak or drive pressure leak first. it could be your drive pressure gauge your hearing (if its leaking)
