Injector Copper O-Rings Reusable?
Mikey
Drag Racer
Jun 13, 2009
560
Are Injector Copper O-Rings Reusable or should they be replaced every time an injector is removed?
Thanks!
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
I wouldnt reuse them as copper distorts once pressure is put on them, essentially flattening them.
They are cheap enough to just use new ones.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I have reused them... I think Pat mentioned he uses some fine sand paper to clean them up. If they look good run them. They aren't much money either.
The o-rings just keep dirt from packing around injector body and the cylinder head. I use Cat silicone o-rings, much cheaper for me.
13,714
776
I've reused them plenty of times without a problem. I guess I've been lucky which I find odd since I usually have crappy luck.
