injector balance rates ????
LBZMIKE
Nov 15, 2014
62
colorado
This is the same tune it is 45 degrees after i drove the truck 90 miles tuesday and today it looks good ?
9,905
151
I'd be happy with that. Bad fuel or something before?
LBZMIKE
Nov 15, 2014
62
colorado
Idk im installing my fass 150 tomorrow and deleting the factory fuel filter so we will see how much better it is
LBZMIKE
Nov 15, 2014
62
colorado
Ok lift pump is in and holds rail pressure at desired and drives much better on the top end ...BUT i left my negative battery cable loose when i went ffor test drive and now im getting a v0100 lost communication with ecm/pcm ??? Where did this come from what does it mean ...truck runs fine
9,905
151
It means you had low voltage and it likely caused a drop to the ECM. Clear the code, tighten the battery connections and see what happens.
LBZMIKE
Nov 15, 2014
62
colorado
Did that and cleared it 3 times and it is still there no CEL some could it be one of those that takes a few cycles of the key to go away ? It doesnt seem to be an issue other then bugging the crap out of me lol
9,905
151
Quite possibly requires key cycles or EFI Live/Tech 2 to remove. Need to see if it's an active code or how many times it was set to be sure the problem is gone.
LBZMIKE
Nov 15, 2014
62
colorado
Got power for the lift pump from the red power box used for jump starts and ground is bolt on motor and i still need a good key on ignition source im using the parking lamp fuses and i need a better fuse thats not controled by lights
