can a lifted cup be re-used if you put on new seals? just pulled one with injector.:mad:
Vrabel TOYAHOLIC May 22, 2008 3,434 0 0 57 Hewitt, NJ Nov 10, 2013 #1 can a lifted cup be re-used if you put on new seals? just pulled one with injector.
Evan@InglewoodTrans yerp Vendor/Sponsor Aug 5, 2010 3,118 65 48 40 Western MA Nov 10, 2013 #2 As long as the cup isn't damaged yes it's fine to reuse it. I've done it many times without issue.
Evan@InglewoodTrans yerp Vendor/Sponsor Aug 5, 2010 3,118 65 48 40 Western MA Nov 10, 2013 #4 If the sealing surface looks perfect then you should be good to go.
adeso wait, what? May 30, 2011 1,569 0 36 Minot, ND Nov 10, 2013 #5 They don't cost that much. If you suspect it damaged at all or warped then I would replace it. I reused all of mine but had one that was suspect. I replaced it 1000 miles later
Vrabel TOYAHOLIC May 22, 2008 3,434 0 0 57 Hewitt, NJ Nov 10, 2013 #6 cost isn't an issue. its my DD and need it done today
Big Block 88 Multiple choice muscle Nov 3, 2008 4,665 0 36 38 Kansas when I am home Nov 10, 2013 #7 I would replace cups if there is ANY doubt
