Just picked up my L5P last Friday. Looking forward to an Inglewood trans cooler upgrade. What do ya say Mike, when can we expect one to hit the market? Not to sound too anxious or anything...
What kind of temps are you seeing with the new truck and under what conditions?
Only 100 miles on the truck so far, too early to say.
Pressure will be higher and so will temps. To what extent, I don't know. I know what they did to the trans but I haven't seen it yet.
Converter will be stronger, input shaft will be bigger, pump will be different and valve body will change and so will software. I can make it better when I see it.:thumb:
So far I am only seeing 160's on the trans with just under 2K on the odometer.
Hate that you can only see the trans temp gauge when in tow haul mode. However I do have the scangauage II hooked up and it seems to match the temp gauge.
120F or higher.What temp does the transmission have to get to before you can put your foot in it safely?
120F or higher.
