In need of some wisdom.
Antiher03
Nov 10, 2013
165
Utah
So I have been looking into this ht turbo kit
Will there be a problem with it not being gated? Also is htt a good reliable turbo?
Mods are built trans with 30% injectors on an lb7
Huffy67
Dec 26, 2014
270
Arkansas
I know there's a big money difference but usually you get what you pay for. I LOVE my HSP 366 kit on my Lb7. And there's a couple members on here that will vouch for the quality, looks, and performance. And besides, why not spend a little extra and do it right the first time!!
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
This
Antiher03
Nov 10, 2013
165
Utah
I would love to go that route, but it's like $2300 just for an install kit! Granted you get intake downpipe and inner cooler tubes
Huffy67
Dec 26, 2014
270
Arkansas
Yes you get EVERYTHING you need. Very nice parts, big ybridge, big tubes, boots, clamps, big downpipe, pedestal, oil lines, big cold air intake, parts and instructions to modify a fuel line around the big ybridge and delete the fprv. May be forgetting something but... I paired mine with profab up pipes and mani's, 45% exergy's, Danville modded lbz pump, head studs and marks tuning and it runs awesome. Looks awesome too!! I think my kit was like $3150 but that included the turbo and everything powder coated.
Whatever you do, make sure your 366 has a 360 bearing in it or it will not last. The cheap ones you find on eBay or other places are junk.
CaptPhil
1,012
Delaware
You dont need a gate on stock fuel with a t4 turbo.
Definitely make sure it has a 360° thrust bearing.
You will need to get a new hotside pipe, or finagle it to make the stock one work until you can get a new one. It wont be tall enough to fit properly. I ran with the stock one for a few thousand miles, just got a longer boot to make it fit.
onebaddmaxxx
1,212
Cecil County Md
It will be fine, as the HTT peds are only 4" risers not 7 like yours. A boy local to me with an lb7 and s366 ran a stock boost tube for a while.
Antiher03
Nov 10, 2013
165
Utah
Well shit maybe I will just see what joe can do for me. If it is a bit cheaper to get it bare I don't think it would bug me all that much. So as far as the t3 it would need to be gated?
Are there even any gains with the t4?
Antiher03
Nov 10, 2013
165
Utah
I was throwing around the idea of going with a 400 frame but honestly I am worried about not being able to tow with it. So I decided to see what pricing Hsp, Wehrli and sdp had for me, sdp hasn't gotten back with me yet but they all seem about the same price if I get the turbo through them. Hsp's kit is $2400 + 750ish for a turbo and Wehrli was $2200 + 850ish for a turbo.
Is there one turbo that will perform better than the other? Besides the 360* bearing?
Antiher03
Nov 10, 2013
165
Utah
Well I pulled the trigger
S366/73/.91 T4
I am going to either try polishing the cover or get it powdercoated chrome
Antiher03
Nov 10, 2013
165
Utah
So can anyone point me in the right direction... Turbo is out, and I am to the fuel lines. Am I supposed to pull the banjo bolt out of the fprv and cut the lines around it to install the plug?
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
I'm from Lehi not too far from you! I'm in search of more air as well. But I'd prefer nitrous over a turbo. Well only because its cheaper. I plan on twins soon tho maybe S475. Or I might go the same route as you and do single 66 and add the 75 when I get rods.
