Some early lmm's would cook the converter in high idle or pto raised idle.
I wonder if that's why Mine is shitting the bed? I've been running a stock tune for some time now and I went to my 100 horse tune the other day and the conver slipped like it's been raped on a 150 tune.
nope....
they fixed that in late 2006.....It was a problem with the truck going into heater performance mode (which, yes, is different than PTO/high-idle because it stalls the turbine in the trans) in the extreme cold while the trans fluid was still thick.
So it was a combination of Dexron VI being shit in the cold, and the truck being programmed to go right into heater performance mode after cold start.
The fix is either get the updated TCM calibration (which obviously all early 2007-on trucks had) that waits until trans fluid temperature is above a certain amount before the trans engages heater performance mode....OR change your fluid for something less shitty and more designed for cold temps.
Was this an issue with early 6 speeds only or 5 speeds aswell?
nope....
You dont know everything there almighty. Your wrong, a had a freinds burn up bc of high idle pto so duck off...
I could care less what your input is so dont bother responding...
My buddy's 07 LBZ already had the updated TCM software in it from the factory, if that means anything.
Mine didn't. Purchased in April '07. I had to bring it back for the update. But definetly anything released in late '07 and certainly in '08 should have had the update.
Coud be. The PO let it sit and high idle a lot?
