Amazons dimensions aren't always accurate. I guess we'll see what comes. Let me know which works. I changed my whole assembly and it does in fact have a metal pulley
But no flanges.
Now within the last two days my belt jumped over a groove. And it's already bothering me. Must jump when it stops suddenly when the motor turns off. Never done it before though.
What about this one?
DAYCO Part # 89051
Just for future reference. It isn't that big but it doesn't fit on the tensioner by about half an inch. I still haven't sent it back so I'll measure it.I never ordered it, I wasn't gonna risk it with Amazon's ridiculous product dimension descriptions.
should have ordered a dayco like I said earlierShould have ordered an entire tensioner but they only had plastic pullies upon initial search so I gave up on that search.
Makes sense, thanks! I got the Delco one out of curiosity. I'm not a fan of the plastic pulley either.The Dayco 89051 was the correct size I had to ditch the factory retainer washer as it was cupped towards the inside. I used a big heavy duty flat washer that covered the surface area so that the bearing would be covered should it decode to come apart.
What I just said makes sense iny head, not sure it it sounds right on paper but it works and is safe.
P/n?should have ordered a dayco like I said earlier
Yeah I know now.should have ordered a dayco like I said earlier
P/n?
The Dayco 89051was the correct size I had to ditch the factory retainer washer as it was cupped towards the inside. I used a big heavy duty flat washer that covered the surface area so that the bearing would be covered should it decode to come apart.
I didI saw that. I though noreaster meant a whole tensioner assembly.
Thanks!
I did
89259 is the # for the dayco tensioner, I'll never run anything but one of those
4 years of running them on 2 trucks & never jumped a belt
