Idle smoke
pappyspal
Aug 8, 2012
13
My 04 dmax smokes when it idles. Other than this, it runs fine. Its stock except for the air intake.
What could cause this? Injector or a sensor? Gona have it looked at next Tuesday. What do ya think?
pappyspal
Aug 8, 2012
13
Look guys. Im not a diesel head. I know squat about them. What I do know, is the smoke at idle is not right. Im going to have the truck looked at Tuesday. Its fuel smoke, black, other than that it runs good. Im trying to geta feel as to whats goin on. I dont know what motor it is.
Just looking to get educated a little before I go to the shop. Its a 2004 GMC 2500HD.
Thanks for your help.:thumb: By the way, it smokes pretty good. My air cleaner is clean. I have a reusuable and just cleaned it. The only mods I have done is a Truflow air intake. 134,000 miles on the motor.
Dirtymaxx03
3,109
If you barely touch the throttle at idle and raise the rpm's a few hundred does it go away or smoke more?
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Hope you have some cash set aside, and get a reference to a mechanic in your area who knows duramax fuel systems, not just a guy who knows diesels! Try to do some reading and learn about your truck too, giving the proper info helps you get the correct help :thumb:
pappyspal
Aug 8, 2012
13
Need injectors, so they say! Its LB7 motor with 134,000 miles. The pressures are good (34) and the fuel pressure regulator is good. What do new injectors cost, and the cheapest place to by? I was told about $275 each.:confused:
5,806
There are a couple cheap places to buy but you get what you pay for. buy reman bosch injectors what ever you do. plan on payin 220+ per injector
