What if we put the tunes on in canada
I think I would be the closest then :roflmao:
Any idea when you will be on the dyno... Definitely don't want to miss that part at the event.
Haha should be interesting then :woott:
still extremely bummed my white truck isn't done and ready.
But cant wait to finish it will all the new parts im adding
I saw it at woodburn but didn't have a chance to talk to you I was pretty bummed its a sweet truck :happy2:
And will probably be way more badass soon?
New Gt5541 106mm, new SoCal 9100 alt firing order cam (currently running hamiltons biggest cam so will be cool to see differences), new HSP billet manifolds, and a Nitrous Express kit
should move out
should move out
http://duramaxdiesels.com/forum/showthread.php?p=746119#post746119
It was the first time testing on the dyno, and the truck didn't like it. Made 386 HP at 2400 rpm then the abs system turned on the brakes. The dyno graph shows the HP climbing fast from 2000 rpm to the 2400 rpm when it shut itself down. Dustin didn't get another chance at the dyno to see if we could fool the ABS system as it was a very busy event. Hopefully we'll make some time after world finals for some dyno testing and have some better results.
The fuel pressure drop shows a lift pump will be pretty mandatory for anything much over a street tune.
Yep, my H&S on hot will not run at WOT when I hit 4th gear, I have to lift and stomp again.
I'm ready for some tuning, keep it up!
