Hi everyone- As you guys know, I currently stock Duramax ECM/TCM pins and connectors, as these are commonly needed for DSP-5 switches, overdrive lockout switches, high-idle wiring, etc... Dealers rarely have the correct pins in stock, and if they do have them in stock, they are usually overpriced and difficult for the parts counter to locate.
Anyway, recently I have had lots of people emailing me and PM'ing me looking for other miscellaneous GM connectors/pins that are used throughout our trucks.
In that light, in order to better serve you guys, Im looking to start keeping a wider range of GM connectors/pins in stock so I can get them shipped out to you guys much faster, and for less overall expense.
Im looking for input on what various connectors and pin are commonly needed and you guys would like to see me keep in stock and readily available...
To start out the list, here are a couple items that I am thinking of...feel free to add to the list and Ill do my best to get them stocked and available in my online store!
-headlight connectors/sockets
-speaker connectors/pins (as these commonly corrode resulting in a dead speaker which can make it appear like the speaker is blown)
-instrument cluster pins (these are also used in the radio connectors, BCM connectors, etc)
-ABS wheel speed sensor connectors/pins
-transmission speed sensor connectors/pins
-engine wiring harness bale connector pins (sometimes these pins get bent/wrecked when disconnecting/connecting the two big bale connectors on top of the engine)
What else?
thanks
Ben
What else?
thanks
Ben
