I just bought a 2004 chevy duramax 3500 crewcab lb7 with 185000 miles on it and it's completely stock I'm not sure if the injectors has been replaced yet I'm not sure on to much info on it but I gave $6800 for it which is a good deal to me with the mileage and how good of shape it's in but when I bought it i was rptest driving it and it was going into limp mode and the water in fuel light was coming on in message center and has a slight hesitation to it not bad though stills idles good and seems to have plenty of power but can tell something is wrong, we'll I just put hot shots secret additive in the fuel tank then went to do the oil treatment to and drained the oil and it had a massive amount of fuel in the crank case I drained like 4.5 gallons of oil total which is way more then what it's supposed to have and I put the treatmeat in and it fixed the oil pressure problem it was having but my question is could a stuck open injector cause it or a leaking return line and how can you tell which one it is without tearing into it and also with the water in fuel light on is there a sensor that can go bad I bought a fuel filter to put on it to see if it shuts the light off but didn't get to it after changing oil please let me know trying to see if something else is c wrong before spending a lot of money on injectors and before dropping the tank to drain fuel out and find out the sensor for the water in fuel is just bad
