So here is the deal I had another thread seems to have died I know patience but its my Dr and its getting old. Rail pressure drops to 11 k at wot and then when I let off spikes to the desired of 23.5k. So on the other thread they said unplug the connector on the back of the fuel pressure regulator and if it goes to 23 k and stays there then its bad fpr if it goes up and down the I have stuck injector. So I unplug the fuel pressure regulator did not move from what it was at. At idle. So my question is where do I go from here. My balance rates are all +/- 2.5 and just extra info with lift pump on it will have actual rail pressure at idle be 2-5k above desired that also makes me lean towards the fuel pressure reg. Let me know
