What does this mean? I sprayed water over the condenser to help flush and then the ac came on for about 20mins. Then it shut off unless I put more water over it. Help please?
Mmy?
The ambient temp is 85. I had the system vacuumed and recharged. All pressure levels read right where they should be. No it doesn't not work driving down the road unless I wet the condenser first the drive it will last about 30 mins.
I wonder if the ambient temp sensor has anything to do it
02 CCSB efi live,head studs, S&B intake, 4" straight pipe to 5"
If the fan clutch was bad wouldn't the truck over heat?
