If you still have the plastic skirts between the wheel and frame ditch them. We use the factory oil cooler as a double pass for the trans, and use the stock D-Max oil cooler without issues. Since yours has atleast a 2" body lift, make sure the gap between the hood and rad/IC is closed like factory. If not the air just passes over the rad/IC and not forced through.
