What turbo(s) would work with this setup that sits in the stock location?
I changed mine to a BD MAX S300, will that work or do I need to go back to stock to put this kit on my 2001 GMC?
Will it work on a 2001 GMC as the AC lines are run different?
How does it connect to the existing turbo intlet? Band clamp? Boot?
Also my turbo outlet is 3" Band clamp not the stock setup with a bolted on down pipe.
How does the interconnect exhaust pipe connect to the existing turbo?
Sorry for all the ???
But would really want to get this and need to know if it will work...
Love the Blue, Would look great under my hood...:thumb:
Thank You...
Jake is correct, we can make it work, but would most likely need your charger here. A few of the connections and tubing would be different.
