HSP Billet Front Engine Cover
joe@HSPDIESEL
Jun 25, 2013
220
HSP is excited to release our latest product to the public. This new billet front engine cover will allow you to run 1-3 reverse rotation CP3 pumps being driven off of the cam gear. The factory water pump can be retained if only running 2 CP3's. Up to 5 CP3's could be utilized. Depending on your application a belt may only be needed for an alternator and power steering pump. In certain applications a serpentine belt may not be used at all.
Another advantage of this billet cover is removing the factory CP3 from the valley to gain space for custom intakes and allow easy access to the pumps should an issue arise.
Price is TBD. The complete kit will include high pressure fuel lines and all hardware needed to make installation a breeze. We can provide reverse rotation CP3's for all levels of performance.
We are working with Jeremy at Wagler Competition for engine dyno testing to provide performance results and ensure the quality meets HSP standards for overall fit and finish.
9,905
151
B.C.
I'd like to see a pic of one with dual cp3's and all the factory accessories needed as one would have if set up in a stock engine bay. Just for clearance and belt routing purposes.
Great looking piece!!:thumb:
MSEngineering
EnvoyMax
Sep 7, 2009
27
Orlando FL.
We will know more next week after we finish up the engine dyno testing. We are shooting for $2,500 with high pressure fuel lines, but that is not final.
Looking forward to it, I like how compact it makes things, takes up less space and uh the billet cover gives extra points for being shiny :p , but yeah I definitely want to purchase one.
moparkxracer
2,309
33
Out and about
Can you imagine 5 12mm stroker cp3. What size injectors would not keep up with that....that's like having 3/4's of one cp3 per cylinder. Lmao.
