I had been thinkin bout this some and prolly the best place for the venturi (most vaccum draw) id say right before your exhaust opens up to bigger size. EX:// I have (for now) my 6" mated to my stock downpipe and chunk of the front pipe. Well where it adapts from 3" to the 6" i have a merge cone conecting the two. Now fast hi-velocity gas moving through the DP emptys into the large volume/lower psi of the 6" and by design will pull a "vaccum" at that area. So ideally IMO i would place the venturi a few inches forward of the transition in the hi-velocity stream. Now there can be psi in the exhaust but by effect of the venturi design, flow past it can still create a vaccum in a psi enviroment, but to maximixe effectiveness, proper placment is needed. So if your exhaust has such a spot in it, might think bout placeing it there. JMHO, since this is uncharted territory. The fact that there is a minor psi present in your PCV system already is good for makin this work. That checkvalve is insurance against pressurizing the crankcase. Hopefully it works so good that a vaccum is created in the crankcase! then you'll reap the benifits of improved ring/gasket sealing! I wish i were there to help! One of the best ways of checking to see that its working is with a slack tube, also called a Manometer (google it). You can buy one or build your own, very simple! We use one at work to diagnose PCV systems all the time, big maker of them is Dwyer, we got ours from Grainger, bout $200 though! If any you guys are intrested, ill make up a drawing and such for a homemade manometer, very handy tool.
