So i'm fed up and racing season is over. I got in ZERO good passes this year and am going on my 6th time of pulling the trans. Other then sending my trans to Mike, which is not feasible from up here, what do I need to do to make my trans live? I had it on a real small tune ran 11.99@115 and then turned it up and adios C1 clutches.
I have replaced the whole drum, seals, pistons. C1's have fried twice, c-3's once, c-2's once, c2 hub/p2 planet once. Im am careful when I build my trans clearances all good. I have never had a problem until I put the horsepower to it now it won't live.
Whats done:
Alto C-5
GMAX C-4
Dual sided C-3 that Suncoast sent me because the GMAX ones didnt hold
alto c-2
16 SS C-1
Transgo/lockup valve with check ball removed and longer spring
ML pressure spring/Drilled seperator plate at pump
Cooler
1055
I am at a loss and would appreciate tips and advice.
Thank you
Reece
Whats done:
Alto C-5
GMAX C-4
alto c-2
16 SS C-1
Cooler
1055
Thank you
Reece
